03 7.3 cranks,little white smoke out pipe
Old Mar 24, 2010 | 04:10 PM
schwing's Avatar
Default 03 7.3 cranks,little white smoke out pipe
i have a 7.3 03 powerstroke it would'nt start a couple weeks ago. i changed the gpr
and it seemed to help, drove it for fore days and it started missing, now it wont start.
i checked all the connters, the conector for the hpo seemed to have oil in it sprayed it with ether to clean it out still wont start, it has a yellow cps, while cranking engine over with scan tool easyscan 5000 it shows engine 350 rpm but no timing advance or ipr 0% no ipc
any thoughts thanks
Old Mar 24, 2010 | 07:37 PM
CSIPSD's Avatar
Unplug the ICP sensor and try again. The computer will default to stored settings.
Check the HPO res and make sure there is oil in there, should be about 1/4-1/2 below the top.
DO NOT start off ether.
Old Mar 25, 2010 | 07:57 PM
schwing's Avatar
ok thanks for the reply !!!!! were is the hpo res ?
Old Mar 25, 2010 | 09:43 PM
CSIPSD's Avatar
red arrow is pointing to an aftermarket oil pressure sender, but on your truck there will be a plug there. Remove that plug and check and see where the oil level is. Do this first thing before cranking on it in the morning. It should be very near the top of the lid.
Old Mar 27, 2010 | 12:38 AM
Kyle_KleinSS's Avatar
Check the basics as well, fuel filter maybe the truck is low on oil. If you have a problem Joe can usually fix it!
Old Mar 28, 2010 | 03:53 PM
schwing's Avatar
ok the hpo res is 1 inch below the top of res !! the icp is the three wire connector
in the front driverside head on the 7.3 ??? oil in engine is full,will change fuel filter for good measure! have to change starter monday as i fried it !! thanks again for all the help
Old Mar 28, 2010 | 04:24 PM
Smoky Bear's Avatar
where is the ICP sensor on the 1999 7.3?
Old Mar 28, 2010 | 07:11 PM
CSIPSD's Avatar
Blue arrow is the ICP sensor...
Old Mar 28, 2010 | 08:11 PM
Smoky Bear's Avatar
Thank you. I will have to try that on mine too. I am up for ideas on how to fix it. I going to try to add some mods to it but i am scared to do anything with these problems...
Old Apr 8, 2010 | 06:32 PM
schwing's Avatar
ok changed the starter, cranking the engine over it would try to start then stall, pulled the icp plug it was full of oil, cleaned it with eather pluged it back in and it started, ran ruff for about ten min then cleared up, drove it about one block and it started missing
barly made it back, it seems like a fuel issue no smoke out the tailpipe that i could see
old filter had a lot off black stuff running out of it when i sprayed it with cleaner, but i
didnot see any rust chunks could the icp cause this ? or was it just a fluk it started when it did ? ps thanks for all you people
as i was reading in other thead there is a mixing valve in the tank iam at a quarter tank
iam going to put more fuel in and see if problem still persist!! i know now why it is the
D BOMBERS SITE THANKS AGAIN
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
mihilo
Sep 16, 2015 10:42 AM
motocox_307
Sep 8, 2015 09:09 AM
Domrig13
Dec 12, 2014 01:24 PM
