Basement Enterprises Products You Make Or Sell
PPE Lift Pump Install Kit
Old Mar 20, 2010 | 06:01 PM
Seth999's Avatar
Default PPE Lift Pump Install Kit
This like my other kit contains stainless steel braided hose with a teflon liner. This kit comes with what you need to plumb in your PPE lift pump on a Duramax when mounting on the frame rail (or other places if your creative). You will need to mount the pump upside down which is perfectly fine according to the directions with the pump. With this kit you simply cut out the section of fuel line which these lines will replace (approx 1.5ft.), screw the 1/2" npt line ends into the pump sealing with teflon tape or sealer, mount the pump, then put the compression fittings over the stock fuel line, and tighten with a wrench. Also if you ever want to remove the lift pump you can reuse the piece you cut out and plumb it back in with two 1/2" compression fittings. This is the only kit of it's type out there that I know of.
PM me for the fastest responses
Price:
Kit including both lines = $125
Small diameter tubing cutter = $10
(reusable and great for tight spaces)
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Apr 29, 2015 08:20 AM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
