Help! My automatic transmission is stuck in first gear, no upshifting!
Old Mar 20, 2010 | 12:40 PM
baymen's Avatar
Default Help! My automatic transmission is stuck in first gear, no upshifting!
I have a 1999 Dodge 250 5.9 l automatic with 60,000 miles. the transmission is stuck in first gear and no upshifting. Is this a easy fix? Or a complete overhaul? I haven't towed anything, don't use 4 wheel drive yet, so far babied it and it has had just leisure driving. Should this have happened with so little miles? Any help is appreciated.
Old Mar 20, 2010 | 06:28 PM
Does it doe this no matter what throttle level?
Old Mar 20, 2010 | 10:17 PM
moved for better exposure
Old Mar 21, 2010 | 11:56 AM
Diesel Nut's Avatar
Are you sure its stuck in 1st and not 3rd. Typically the transmission limp mode is direct drive and lock up and od will not work, and the transmission will not downshift. If this is the case then you could have a small problem like a transmission power relay or fuse blown, transmission power wire short to ground or open circuit, PCM could be corrupted, there are several possibilities.
Old Mar 22, 2010 | 11:55 AM
Chvyrkr's Avatar
Speed sensor goin out will cause it to stick in first gear. Simple fix, I'd start there.
Old Mar 22, 2010 | 12:54 PM
96blackcloud's Avatar
mine stuck in first once cus i used to be able to mannually shift through the gears till drive. the linkage binded all it took was a little shake on the linkage and it would come out.
Old Mar 22, 2010 | 12:56 PM
Chvyrkr's Avatar
This is a 24V I'm guessin? Has an electric speed sensor on the output shaft? If that ain't workin, the trans will stick in 1st gear. Simple fix.
6.2Lturbo
Chevy/GMC Duramax 01-04 LB7
Aug 15, 2015 01:25 PM
Hotrodd_67
Jun 22, 2015 09:50 PM
SixSpeed
Jan 11, 2015 01:41 AM
smokee
Nov 7, 2014 07:40 PM
collind82
12
Sep 30, 2014 11:23 PM
