temp guage sporatic reading
Old Mar 18, 2010 | 05:19 PM
streetrod's Avatar
Default temp guage sporatic reading
today my 95 ctd temp gage started doing something weird it dosent read temp unless you are standing on the throtle or it sits at an idel i have checked colant and it fine but this gage is making me very nervious i have also stuck my finger into the colant and it warm not hot after 30 mile drive
Old Mar 19, 2010 | 09:56 AM
mjp5318's Avatar
Sounds like the guage, or better yet the sending unit that actually reads the temp has gone fualty on you.
Old Mar 19, 2010 | 03:12 PM
Deezel Stink3r's Avatar
Hmmm, be alerted.
check electric connections (have an eże on ground connections) Sometimes it helps to diconnect and to connect them several times to get rid of surface corrosion. Also spray a bit WD40 into the connectors.
Check your thermostat, maybe it is constant open. Coolant should be at op temps after a 30 mile drive.
A cross check can simply be done with an IR gauge.
Old Mar 20, 2010 | 07:45 AM
streetrod's Avatar
i have added a quart of coolant. i dont hhink the stat is open it dont have much flow through the radiator i will losen the grounds today after work and see if problem goes away
irondog1954
Jul 21, 2015 09:57 AM
doodieroot
May 10, 2015 11:48 PM
stewart.william.c
Feb 11, 2015 01:39 AM
emilio2496
8
Jan 13, 2015 05:03 PM
joejack6.0
Oct 25, 2014 05:41 PM
