VW Diesels Discussion of all things Volkswagen Diesel - TDI, Bug , Touareg , Jetta , Golf , Passat
VW TDI Twins?
Old Sep 2, 2007 | 08:20 PM
Wyatt Earp's Avatar
Default VW TDI Twins?
Has anyone every done that? I was under the car today fixing the lower intercooler pipe and noticed that there is tones of room down there for another charger.
Any ideas?
Old Sep 2, 2007 | 10:07 PM
Buckshotmckee's Avatar
Sma't Alec!
Yup! It's called a Toureg!
I'm not sure on how you'd get that little engine to hold the boost.
Old Sep 3, 2007 | 11:56 AM
Wyatt Earp's Avatar
well, stock it is good for no more than 24 psi. but if you put studs on it and a better gasket since the chargers are small - could you get it to 50?
Obviously you'd need a real front mount intercooler and some other mods as well but there appears to be enough room between the charger and the firewall.
Old Sep 3, 2007 | 02:40 PM
rufushusky's Avatar
How about s300/s400 twins...hahah jk.
Old Oct 10, 2007 | 10:56 AM
Wyatt Earp's Avatar
What are the smallest turbos that are readily available? Garrett or Holset or someother brand. I don't know spec's but what if you could get a 4cm housing and a 6 or 8cm housing?
I still think it can be done. The head on the motor would need beefing up because they don't hold too much boost but with a front mount intercooler and a set of studs that might be a bit better.
Ideas...
Old Oct 10, 2007 | 11:46 AM
DBogo's Avatar
IHI, KKK, Mitsubishi, Garrett they all make some tiny turbos, use the stock for the smaller turbo, and look at some turbo small construction equipment for the slightly larger one, i know the perkapillars got some tiny turbos on them, check like a skid steer or a wood chipper or something with a tiny diesel in it
Old Oct 11, 2007 | 03:19 PM
YMMOT's Avatar
Stock turbo on a TDI is a Garrett VNT-15. Small turbos out there that are reasonably common are T-28 and T-3's. The latter has been SVO Mustangs and MANY of the 79-85 Turbo 3.0 Diesel Merecedes engines.
There is the GT series that goes down to a GT12, but that is WAY to small of flow. Minimum in the GT series I would consider would be a GT20.
Personally I think if I was going to change the wife's Turbo I would go to a Garrett VNT20. That is the turbo from an A6 Audi that had the 2.7 V6 in it. (circa 2004)
Old Nov 2, 2007 | 12:59 PM
Diesel-Dan's Avatar
Just tossing this out....BUT what about a VNT-15 with say....an HX-35/14cm?
Dont thing the though hasnt crossed my mind with ours! hahaha.....
Old Nov 4, 2007 | 10:57 AM
YMMOT's Avatar
I still say a VNT-20 is more than enough. The VNT-20 has enough flow to provide a 2.7L V-6 265HP@5800RPMS and 258lbs-ft@1850RPMs. The Second turbo would just add complexity in the plumbing that you really don't need.
Old Nov 4, 2007 | 02:15 PM
Wyatt Earp's Avatar
True, but just to say you did it. Built it, marketed it and so on would be pretty cool.
