92 Headlights flashing
Old Mar 10, 2010 | 09:22 PM
dolmstead2007's Avatar
Default 92 Headlights flashing
Well after replacing the dimmer multi switch on the column and buying new headlight buckets and new bulbs cleaning the grounds. The issue is back of the lights coming and goin just sitting or driving it gets worse while driving. Any ideas?
Old Mar 11, 2010 | 01:12 AM
ArizonaRedneck's Avatar
have you checked your wiring for rubbing from the headlights back to make sure no rubspots
Old Mar 11, 2010 | 10:07 PM
I looked the bundle over but didnt see any rub spots. I noticed last night theres quite alot of under hood heat. like alot more than my 88 ever gets. you could feel the heat radiating about 3 feet away after driving for 20 minutes. Im wondering if theres like a relay or something under there thats getting hot?? idk ill have to get a manual for it tonite. bc its more like a pattern flash but the headlights are the only things affected no other lights alt is putting out steady. Got me baffled here. IF i can find my cable to my phone ill try try uploading some video of it doin this. Maybe it might give you guys a idea of what im seeing and tryin to explain
Okay well went and searched today cant find a chilton or haynes manual that includes andything for the diesel they say gasoline engines only. So im guessing the wiring is probly different fromt he gas and diesels too? sorry for the bad video and sound my cameras broke so i had to use my cell phone
Heres a video i recorded tonite of the lights doin the flashing stuff
And heres another of them flashing
http://
Last edited by dolmstead2007; Mar 11, 2010 at 10:07 PM. Reason: Automerged Doublepost
Old Mar 11, 2010 | 11:33 PM
can you here anything under the hood any type of clicking at the fuse box like a weak breaker or anything like that
Old Mar 12, 2010 | 11:19 AM
I cant hear any clicking goin on but then again its hard to hear anything with the engine running. Ive read that theres a big problem with the headlight switches being overloaded and popping a circuit breaker thats built in the headlight switch. Supposedly theres a fix by running a headlight relay kit that you can get from LMC trucks. Idk if I coulda overloaded it when i hooked up all the running lights? Im gonna go tryin to swap a new switch in and see if that helps. It could be the original has had enough with 200k iles on it.
Old Mar 12, 2010 | 12:35 PM
Sycostang67's Avatar
I would try the headlight switch, it's a common problem on a lot of fords. It happened to my 67 mustang, and my 85 F-250. They get old and dusty and cant handle the load as well. The headlight relay is a worthwhile upgrade, it removes the load from the switch and puts it on the battery. I've heard nothing but good things about that mod.
Old Mar 12, 2010 | 01:03 PM
glad you are on the right track to getting it taken care of
Old Mar 12, 2010 | 03:10 PM
OKay went out and took out the cheap china junk headlight switch out and put a motorcraft in and so far its been okay. drove it around for the last hour without any issues. I purposely ran alot of stuff to add a load to the system and see if it caused it. Im still plannin on adding the headlight relays. I think i maybe with all the extra running lights and stuff i added it may have been just enough with a bad switch to cause problems.
Old Apr 8, 2010 | 05:00 PM
Gunpowder's Avatar
Every Ford I ever owned needed a headlight switch especially without a relay for other lights.
Old Apr 10, 2010 | 08:55 AM
cornfed's Avatar
just adding to it my switch has went bad twice on my 93, the last time it melted the plug so bad I had to rewire it
Dan7769
17
Nov 9, 2017 06:05 PM
POWERSTROKEMANIAC
Nov 18, 2015 05:28 PM
drgracen
Aug 11, 2015 12:21 PM
carid
Diesel Bombers Sponsors
Apr 7, 2015 07:30 AM
smokee
Feb 14, 2015 12:09 PM
