Smarty question for BOB "CA Users"
Old Mar 4, 2010 | 09:48 PM
dangerous1965's Avatar
Default Smarty question for BOB "CA Users"
Hey Bob sorry to bug but you never got back to me!
Just a few Questions
1) How much timing is too much? If I run propane or NOS what works best? I have a water meth injection system if that matters.
2) What does the on demand numbers mean? 0-99?? And how does it equate between settings such as: # 5 at 70 and #9 at 50??
Don’t really understand what the difference is?
3) What works best for milage I run 65mph at 2000rpm and get about 22 to 24mpg hand calculated! I have the smarty set at # 5 at 70.
4) CA is going to smog diesels what setting will get me through the snap pedal test? Will there be anything downloadable to help your CA owners?
Just so you know I have a 06 dodge 5.9 and the smarty 06 pod
Thanks a lot for your time!!
Andrew Danz
P.S. My mods are 90hp injectors, MP-8, CP3 Arson kit, Head studs Phat shaft 62, Water meth system, airdog 150 at 20psi,
This is a copy I sent in an e-mail in case the e-mails are not getting thru!
Old Mar 5, 2010 | 11:28 AM
RSWORDS's Avatar
I know that the lowest setting ( #0)on the SMARTY is half power. Try it out and see how much smoke you get.
Old Mar 13, 2010 | 03:13 AM
millco's Avatar
That is exactly what that setting is for!!
(If that doesn't impress them you could always try the highest setting! . . . )
Josh_L
Apr 12, 2015 12:12 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
