jeep cummins conversion
Old Feb 26, 2010 | 09:46 AM
joey's Avatar
Default jeep cummins conversion
Has anyone ever seen a cummins in a jeep. Not a 5.9 but a 3.9 cummins the little one that goes in air compressers and generators the 4 cyl. Well i was wondering if anyone had seen one to mabe tell me how hard it would be to do.
Old Feb 26, 2010 | 12:28 PM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/diesel...rsion-kit.html read this thread and see if it will answer some of your questions
Old Feb 26, 2010 | 01:04 PM
Kirk T's Avatar
I am very familiar with those small Cummins engines. They are used in all sorts of construction equipment including Case backhoes and crawler tractors from E series on. They use an SAE # 2 bellhousing (I believe it's #2) and adapting a trans to those is possible. I have seen many forklifts using Borg-Warner manual transmissions behind these critters with a great deal of success. Also, the Case backhoes use a Borg-Warner power shuttle (forward-reverse) so they might be the hot-spot to contact for your swap. Good luck, and have fun!
Old Feb 27, 2010 | 12:20 AM
FTE's Avatar
FTE
There were alot of bread/chip step vans that were converted over to the 4bt. Most of the GM chassis were auto t400 and the Ford chassis were manual. These would be a better source than const. equip. because of the govener. You want one already set up for a truck. Alot of the off-road guys have done this swap.
Old Feb 27, 2010 | 04:42 PM
zjohnsonua's Avatar
x2 FTE. Look for a box/bread/step van. I've seen a few of these 4bt jeeps driving around. The engine works out and fits so well it'll make you wonder why Mopar didn't try the setup themselves.
Dzljon
47
Jul 30, 2016 04:05 AM
Radioking1777
Jun 8, 2015 10:26 PM
Chummins80
Feb 28, 2015 08:34 PM
mt grizzly
Dec 31, 2014 12:13 AM
gixxerman1000
Nov 2, 2014 07:53 PM
