Head studs
Old Feb 21, 2010 | 08:36 PM
dangerous1965's Avatar
Default Head studs
Does anybody know the proper torque sequence and ftlbs for the ARP studs? Any secret # to finalize the torque down How long before retorque is required if required?
Old Feb 22, 2010 | 10:20 PM
jms_shepherd's Avatar
Here is a link for you and the sequence
http://www.truckblog.com/gallery/Aggie007/31715.jpg
Start from 1 and so forth.....From there I would go ahead tighten them to 95 ftlbs and then once all 26 are done....Do them again at 125ftlbs...You can also go one more time to 130ftlbs but thats max....
This is the torque rating for the ARP studs that are like 425bucks....
When you do the studs. You a knickle base lube and use ALOT OF IT be generous with that stuff...... Also make sure you clearance the back of the rocker house injector there is a pic below becuase it will not clamp down all the way....
http://www.truckblog.com/gallery/Aggie007/31730.JPG
Old Feb 23, 2010 | 08:36 AM
Explain this a little more.... The cover needs to be filed down? OR??
Old Feb 23, 2010 | 09:08 AM
Diesel Dummy's Avatar
you will need to clearance the cover to clear the back stud nut, it will not fit with out doing it.,,You just need to notch it on the inside.
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Adam65
Jan 9, 2015 11:50 PM
turbodiesel123
Nov 28, 2014 08:36 PM
HE22871
Nov 26, 2014 03:15 PM
