6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Oil cooler
Old Feb 17, 2010 | 11:11 AM
ATX6132's Avatar
Default Oil cooler
Where can i get an oil cooler for 2004 6.0 f350... cheapest would help
Old Feb 17, 2010 | 11:34 AM
travisdun's Avatar
what kind of oil? I think that it should have both engine and trans from factory.Are you having a problem with over heating.If you need a larger cooler there are a lot of aftermarket coolers that you can just plumb in in place of your old one.you may have to make a couple of brackets.
Old Feb 17, 2010 | 11:57 AM
Deezel Stink3r's Avatar
If I where you I would use a cooler with fan.
If it is temperature controlled, it will assist in cooling under low speed, high load conditions.
Got the same setup and it really pays off itself during offroad.
Old Feb 17, 2010 | 03:03 PM
ATX6132's Avatar
Sorry not to specify but an oil cooler that u have to replace when u replace the EGR cooler is it better to upgrade or will a stock oil cooler perform well with an EGR delete kit
Old Feb 17, 2010 | 03:10 PM
Mdub707's Avatar
Obviously they dont know about 6.0's...
You can buy just a rebuild kit, instead of purchasing the entire cooler. I know Adam from FirstCoastDieselPerformance sells these. Much cheaper than buying the whole deal, unless your housing is cracked or something and you need an entire one.
I know there was a guy selling a pair of brand new ones on powerstroke.org
Old Feb 17, 2010 | 03:40 PM
ATX6132's Avatar
Ya obviously i was like wat the he11? haha but thanks ill check it out n let u kno!
Old Feb 18, 2010 | 03:16 AM
HeavyAssault's Avatar
There are rebuild kits on EBAY as well. I have seen a few complete coolers on there also.
Crabber0001
6.0L Performance
Aug 4, 2015 12:30 PM
tim12valve
May 6, 2015 10:40 PM
Bighouse
Apr 9, 2015 06:51 PM
emilio2496
8
Jan 13, 2015 05:03 PM
bypass-21
Dec 15, 2014 08:52 AM
