Oil in radiator
Old Feb 8, 2010 | 08:25 PM
wireman's Avatar
Default Oil in radiator
I have a 2000 cummins 5.9 24v I need some help with. I have a large amount of oil pushing through the radiator. It starts as soon as you crank it. The truck runs smooth with no miss at all. We pulled the exhaust manifold and there was no sign of water there. It is getting water in the oil. I have already changed the oil cooler and put new gaskets. Does anyone have any suggestions?
Old Feb 8, 2010 | 08:30 PM
Diesel Nut's Avatar
If you already changed the oil cooler then my next guess is either a blown headgasket, cracked head, freeze plug in the head loose or cracked cylinder liner. Pull the Valve cover and see if you have water flowing anywhere. You can run the truck at idle without the valve cover.
Old Feb 8, 2010 | 08:32 PM
blkjack's Avatar
I too would think along the lines of head gasket issue.
Old Feb 8, 2010 | 08:34 PM
wireman's Avatar
Thanks I'll try that.
Old Feb 8, 2010 | 08:35 PM
captain_stabbin's Avatar
i've only seen this once... was a cracked block. good luck
Old Feb 8, 2010 | 09:47 PM
2500HeavyDuty's Avatar
what kind of block is it
Old Jul 20, 2010 | 09:08 PM
wireman's Avatar
This is just an update on my truck in case someone runs into the same problem. The crack ended up being where the main bearings are oiled and the front cylinder wall. I ended up buying a new block and gasket kit rebuilt the motor and its running like a champ.
Old Jul 20, 2010 | 11:15 PM
chpmnsws6's Avatar
Do you know what the casting on the original block was?
Old Jul 21, 2010 | 05:08 AM
wireman's Avatar
It was not the 53. I would have to go look at it but I think it had a A and some numbers behind it.
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
tim12valve
May 6, 2015 10:40 PM
coors_man_2005
Dec 15, 2014 10:23 AM
