4wd light
Old Feb 8, 2010 | 06:28 PM
02max's Avatar
Default 4wd light
anyone ever had to replace there ignition to fix there 4wd service light????????????
Old Feb 8, 2010 | 06:29 PM
jbrown1132's Avatar
nope, i can't say i've ever heard of that one.
Old Feb 8, 2010 | 06:35 PM
02max's Avatar
well i talked with the tech at the dealership and told him my problem and what i had already replaced i.e. switch and fuse he told me that there has been a service bulletin on 4wd lights that was one of three fixes the other two fixes are the switch and the ground wires not being grounded properly (grind the paint off frame)
Old Feb 8, 2010 | 06:44 PM
cumminsdad08's Avatar
is it the switch to tell you its in 4wd or is it a service light, cause my older chevy, the light would stay on for a while after i pulled it out, usually till i shut it off. it never seemed to still be locked in so i just ignored it.
Old Feb 9, 2010 | 10:39 PM
02max's Avatar
it the push button on the dash
Old Feb 14, 2010 | 08:35 PM
02max's Avatar
waiting on the dealership to order my ignition switch module at 145.00 buck but oh well got to get it fix cant play in the snow with out 4wd
Old Feb 16, 2010 | 05:49 PM
my dad inlaw replaced his in a ford ranger like 4-5 times, untill he finnaly wrecked it in the snow, (aperently the 5th time didn't fix it)..........
Old Feb 20, 2010 | 03:13 PM
whiteboyinaz's Avatar
I had the same problem on my truck. It would blink but not do anything. Found out it ws just the ground on the driverside frame from the tranny wire harness, the bolt was stripped out. Easy fix.
Old Feb 20, 2010 | 11:46 PM
02max's Avatar
took the ground off and took the grinder to the paint put bolt back tight still not working all the lights on the switch come on when i first turn the switch on but go right back off
thats what makes me think its the ingition switch
Flikkie2001
12
Aug 29, 2015 10:03 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
yams
Dec 7, 2014 12:51 PM
