fuel leak
Old Feb 8, 2010 | 10:49 AM
codiesel's Avatar
Default fuel leak
so my truck seems to be leaking a lot of fuel and it drips down under neath the motor by the back of it what could it be
Old Feb 8, 2010 | 10:57 AM
bama29fan's Avatar
here ya go....see if this is whats going on with yours. i just fixed mine this weekend. took me about 2 hours...could be done quicker but i was going slow so i wouldnt screw somethin up.
Replacement O-rings for Ford Diesel Engines
http://www.dieselorings.com/docs/FuelDrain.pdf
just follow the directions and you should be fine. My local diesel guy wanted $200 to fix it...i did it for 11$....6$ for orings and 5$ for shipping.
might as well change the fuel filter while you are there. with that you need to know if you have the OEM filter or the aftermarket. after market has the cap attached and OEM doesn't.
Old Feb 8, 2010 | 11:06 AM
codiesel's Avatar
ok ill look in to in but its a pretty efty leak it makes a huge puddle on the ground but i will proble replace thos
Old Feb 8, 2010 | 11:13 AM
bama29fan's Avatar
Mine was also....was leaving a trail in the parking lot at work and a puddle about two feet in diameter. This is most likely your problem as it's a common issue. search around on here you'll see it discussed a lot.
Old Feb 8, 2010 | 08:02 PM
codiesel's Avatar
ok thanks for the help man im planning on doing that this week
Dale9411
Dec 4, 2022 06:51 PM
Dbleo351
Nov 20, 2016 09:34 AM
moneypitk5
Feb 12, 2015 11:01 AM
4x4kingx889
Jan 25, 2015 02:02 PM
Dec 5, 2014 08:30 AM
