6.2 starter
Old Feb 8, 2010 | 03:19 AM
smoking62's Avatar
Default 6.2 starter
grinding noise when cranking. a peice of the starter casing is broken between the bolts but wont fall out.
did i bottom out on something ? the front drive shaft and pumpkin is pretty much below it so how could it get hit . how long could it last
Old Feb 8, 2010 | 06:45 AM
UntrainedEye's Avatar
If the brace that supports the end of it isn't in place, nose cone failure is fairly quick.
Old Feb 8, 2010 | 09:05 AM
smoking62's Avatar
the brace is there but it looks bent almost
Old Feb 9, 2010 | 10:39 PM
2MuchJunk's Avatar
The brace will be bent to bolt to the side of the block. I had to fix a block because the brace was left off on one. It is very important it is on there If the brace is on and tight the only thing's I can think of are.
The stater needs to be shimmed out. The engine kicked back on the stater and broke it.
Or it was just a bad casting.
Old Feb 10, 2010 | 12:29 AM
smoking62's Avatar
thanks budget low so im gonna try to jb weld it or drill and tap some screws to hold it for now
leocanuck
6.0L Performance
Sep 27, 2015 06:05 PM
klein444
Jun 20, 2015 11:48 PM
james2562
Feb 5, 2015 09:05 PM
Caveman94
Dec 8, 2014 12:21 PM
nevadagramm
Oct 17, 2014 07:59 PM
