thermostat removal
Old Jan 30, 2010 | 07:22 AM
tanaka's Avatar
Default thermostat removal
How do you replace a thermostat in a 6cta8 cummins(450c)?
Old Feb 2, 2010 | 12:39 AM
ArizonaRedneck's Avatar
welcome to diesel bombers and what exactly is the problem and why do you need to change the thermostat
Old Feb 2, 2010 | 10:32 AM
Im not exactly sure what a 6cta8 is. What application is that? Agricultural?
It should be a pretty straightforward job and should just be a matter of pulling 3 bolts, pulling the old stat out (its a good idea to test it) and putting a new one with gasket back in. Reinstall your bolts and check for leaks.
I would think it should be pretty similar to this: TSB 07-07-94
Dustin M
May 21, 2015 10:19 PM
DeLuzGN
Mar 17, 2015 08:08 AM
klein444
Mar 8, 2015 08:19 AM
mmnot
Mar 2, 2015 07:12 PM
Gizmo52
Sep 29, 2014 05:13 PM
