85 6.9l died wont start
Old Jan 27, 2010 | 08:52 PM
Dinodidit's Avatar
Default 85 6.9l died wont start
85 f250 no mods. Was braking to a stop and the truck stumbled and died. Replaced fuel pump on block. I am getting fuel to the injection pump none past. I am getting 12volt to the pump. I took off the cover the gear and pump are turning. I believe the injection pump to be bad I did check the solenoid it is working. Any suggestions on a source or site with data on rebuilding the pump? Thanks for all the help in advance.
Old Jan 27, 2010 | 09:01 PM
wildbill's Avatar
Have you got power to the fuel return solenoid??
BTW, it's wise to let a diesel shop bebuild the pump.
Old Jan 27, 2010 | 09:13 PM
Dinodidit's Avatar
I have 2 wires to the pump 12volt to one only the other has about 1volt.
Old Jan 27, 2010 | 09:24 PM
wildbill's Avatar
Run a jumper wire from one to the other. Then try and start.
Old Jan 28, 2010 | 03:42 PM
Dinodidit's Avatar
Tried that still no luck.
Got it going it was a bad relay in the injector pump. Thanks for the help.
Old Jan 28, 2010 | 05:44 PM
the_new_kid's Avatar
Good to hear that....time to go tear it up again ehhh
Old Jan 29, 2010 | 05:11 PM
Dinodidit's Avatar
Ok final update the real underlying problem........fuel filter clogged nbut still putting fuel through. new filter in and I got my truck back.
moose2j
Jun 21, 2015 12:36 AM
ronstop
Feb 26, 2015 09:48 AM
RayRay4991
Feb 23, 2015 07:45 AM
southernbelle14
6.0L Performance
Dec 29, 2014 10:53 AM
Tyler_302
Oct 22, 2014 07:08 PM
