Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Water/Meth injection
Old Jan 16, 2010 | 08:08 PM
jaytric9's Avatar
Default Water/Meth injection
My brother and I are looking around/thinking about trying a homemade injection kit. Now is there a difference with the pumps that I need. Such as a pump for methanol and a pump for diesel fuel, basically as long as i find a pump that pushes over 100/150 psi will it work? I found a 150psi pump but wasnt sure if it needed to be a certain kind of pump rated for use with meth or what.... and what injector/s is/are being used to spray into the intake?
Old Jan 16, 2010 | 11:44 PM
mxtuner1's Avatar
Jay- Just trying to figure what your asking - you dont need to pump diesel with the methanol injection. Just water and methanol mixture and between 50/50 and 65/35 mix for power and economy. All of the manu's will sell you individual parts to make your own system. I have said this on other threads but will repeat again - just watch -with methanol injection the pressures will constantly be going up for better atomization and more flow. Some pullers with water injection make 600 lbs of pressure!. Pressure and flow are important and how you turn the unit on are all important. Good luck- if you cant get any help pm me.
Cougdiesel
Feb 2, 2016 10:17 AM
1997silverado
Sep 11, 2015 11:27 PM
ffmoofus
Jul 19, 2015 11:56 PM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
