Dash problems
Old Jan 15, 2010 | 07:12 PM
bjohnson1781's Avatar
Default Dash problems
Dash gages quit working when key is turned on.Seems like every thing that works through the dash wiring quits.Gages,Chimes,Switched dome lite,and radio.Dash lites still work.Dash repair man checked cluster found no problem there.Any Ideas on what I can check?
Old Jan 15, 2010 | 07:32 PM
ArizonaRedneck's Avatar
welcome to diesel bombers and post your question here will have a better response https://www.dieselbombers.com/ford-p...ke-03-07-6-0l/
Old Jan 15, 2010 | 07:58 PM
mishkaya's Avatar
My guess would be a bad ground under the dash somewhere...
Old Jan 15, 2010 | 08:47 PM
If I ever find the ground I'm going to clean it.I thought about a little four legged furry critter but have not found any chewed up wires.These new trucks got so much under the dash like hunting needle in hay stack.
Old Jan 16, 2010 | 04:08 AM
Jamie Lynn's Avatar
Dang that is stinks..
Old Jan 16, 2010 | 04:45 AM
Deezel Stink3r's Avatar
1. Check your main fuses. Had the same problem a week ago. Local circuit fuses were ok- it has blown on of the main fuses.
2.Try to get the wiring layout and have a close look at the units not working anymore. Just seek for common power supply and for common ground return. Problem should be located there.
Old Jan 16, 2010 | 06:36 AM
12vcummins96's Avatar
also do a wiggle test before you ask whats that grab wires and shake them see if there is a change while you do it if so thats where you need to focus
casper83
Jun 29, 2015 07:37 PM
Brushout
Audio Equipment/Electrical
Mar 18, 2015 10:54 PM
Zachbishop
Feb 10, 2015 10:23 AM
Ol Goat
Jan 22, 2015 02:16 AM
suzan
Dec 2, 2014 03:03 AM
