99 f250
Old Jan 14, 2010 | 11:52 PM
prentis's Avatar
Default 99 f250
it started yesterday morning reverse out the drive way white smoke lost power stop and then wont start
Old Jan 15, 2010 | 08:08 AM
DieselDanBoy's Avatar
need more info, what did it do before it shut off? sounds like a head gasket. how did it start?
Old Jan 15, 2010 | 11:56 AM
CSIPSD's Avatar
Need some more info. Can you get any codes? Have you checked for fuel at the bowl? I doubt its a headgasket, 7.3's rarely eat head gaskets.
Old Jan 15, 2010 | 03:08 PM
prentis's Avatar
it start up sunday morning then the water in fuel light come on i drove it for an hour then the light went out . it started up morning running rought white smoke and no power
Old Jan 18, 2010 | 10:51 AM
ok white smoke sounds like a fuel issue now. fuel may be jelling up. how cold was it?
Old Jan 18, 2010 | 02:42 PM
CSIPSD's Avatar
If the water in fuel light come on then you need to drain the bowl... IF you had a ton of water in there, there is a chance that you blew a nozzle tip off... If there is a lot of white smoke, stop driving it! White smoke is raw fuel and can cause very bad things!
Old Jan 18, 2010 | 09:43 PM
i agree ^
Old Feb 2, 2010 | 09:24 PM
prentis's Avatar
thank i got it running now.it was fuel the fuel filter
Old Feb 3, 2010 | 06:05 PM
you mean water in the fuel filter? there should be fuel in the fuel filter
racinfast002
For Sale
Jan 7, 2015 12:46 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
