powerstroke wont run under a load
Old Jan 12, 2010 | 06:35 PM
racerforlyfe's Avatar
Default powerstroke wont run under a load
hello guys, i have a problem with my 95 powerstroke diesel. it is a 5spd. recently i ran the truck really low on fuel and it hasnt been running right since. i have replaced the fuel filter and also the fuel pump on top of the engine. the truck will stumble at first then runs great. it will rev fine and acts like it should. the problem is that when u try to drive the truck it starts stumbling and missing like its getting no fuel. if i park the truck and let it idle it will settle down and run fine again till u try to drive it again. the truck ran perfect till almost running out of fuel. on several occasions i have let it idle for anywhere from 10min to an hour. problem still persists. i am new to diesels and im trying to learn as i go. i love the truck but i just need it to run right again. am i missing something? PLEASE HELP!
also oil is relatively new and running very good pressure
Last edited by racerforlyfe; Jan 12, 2010 at 06:35 PM. Reason: Automerged Doublepost
Old Jan 14, 2010 | 07:12 PM
Default also cleaned screen PLEASE HELP
i also have cleaned the screens on the filter houseing. this didnt help at all. does anybody have any suggestions here please...i really need to get the truck running correctly again. PLEASE HELP
Old Jan 14, 2010 | 07:45 PM
wildbill's Avatar
Did you change the fuel filter or clean the old one??
Old Jan 14, 2010 | 08:07 PM
greenmonster's Avatar
does it have metal fuel tanks?
if its got metal tanks u coulda sucked the crap that flakes off those tanks and got it in the lines but it hasnt got to the filter, was the filter full of junk when u cleaned it?
Last edited by greenmonster; Jan 14, 2010 at 08:07 PM. Reason: Automerged Doublepost
Old Jan 16, 2010 | 05:13 PM
wildbill's Avatar
Updates??
Old Jan 16, 2010 | 08:40 PM
robammerman's Avatar
Did you just run it low, or did you completely run it out? If it ran out, you may have ruined some injectors. They've been known not to like that.
vin_diesel
Mar 1, 2016 01:43 PM
Tylerbuckley
9
Sep 21, 2015 08:24 PM
rusmis91
Chevy/GMC Duramax 04.5-05 LLY
Aug 6, 2015 04:44 AM
4doorIDIot
6.9L & 7.3L Performance
Aug 1, 2015 06:02 PM
carid
Diesel Bombers Sponsors
Jun 22, 2015 09:33 AM
