engine specs
Old Jan 8, 2010 | 12:36 PM
cummins_guy's Avatar
Default engine specs
bore....................102mm (4.02)
stroke..................120mm (4.72)
displacement...........5.88l (359)
firing order............. 1-5-3-6-2-4
valve clearance....... intake 0.010.............exhaust 0.020
compression ratios.............18.5:1.......17.5:1......16.5:1
oil pressure at idle.........10 psi
oil pressure at rated(minimum allowable).........30 psi
regulating valve opening pressure.........60 psi
oil capacity of pan...........max 14.2.....low 12.4 US.Qts
Old Jan 12, 2010 | 12:51 PM
Uncle Bubba's Avatar
Good info, what years do these specs cover.
Old Jan 15, 2010 | 02:02 PM
these are all stock 6bt, 6bta, and 6btaa.
for dodge application, it will work with all 12 valve, up to 98.5
Old Jan 15, 2010 | 02:09 PM
ArizonaRedneck's Avatar
thankyou for the info
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
hershwork
Mar 1, 2015 05:15 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Oct 30, 2014 08:10 AM
