03 sd 6.0 wont start
Old Dec 27, 2009 | 07:03 PM
blackbomber's Avatar
Default 03 sd 6.0 wont start
I was driving down the road with no signs of trouble and my truck died. no codes. no sputtering. just died. wouldnt start back up. changed fuel filters and now it will crank all day long but wont start. no smoke. nothing.
*bump*
Last edited by blackbomber; Dec 27, 2009 at 07:03 PM. Reason: Automerged Doublepost
Old Dec 27, 2009 | 07:11 PM
wildbill's Avatar
Check the oil level in the HPOP. Also need to scan it for codes anyway.
Old Dec 27, 2009 | 11:49 PM
ok i may sound like an idiot but iam new to diesels in pickups what and where is the hpop? my buddy is bringing his scanner over tommorow.
Old Dec 27, 2009 | 11:53 PM
wildbill's Avatar
HPOP is the high pressure oil pump. It pumps oil under pressure to fire the injectors. It's on top toward the front of the engine.
Old Dec 27, 2009 | 11:59 PM
I will check that in the am thanks for the help. What if it is low
Old Dec 28, 2009 | 12:00 AM
wildbill's Avatar
15w-40 diesel engine oil.
You'll find out more when you scan for codes to, hopefully.
Old Dec 28, 2009 | 02:44 AM
Chvyrkr's Avatar
6.0 HPOP is on the back of the engine, passenger side, under or just behind the turbo. I'm not all that 6.0 savy, but I don't think a 6.0 has an HPOP res to refill, it feeds dirrectly off the LPOP. As opposed to the 7.3 usin an HPOP reservior that is maintained by the LPOP.
Are you gettin fuel to the engine? A 7.3 won't throw codes when the lift pump quits, I don't think a 6.0 will either. Disconnect a line somewhere away from electrical and crank it over, you should get a good spray.
Old Dec 28, 2009 | 11:56 PM
scanner wont link up the fuse to the dlc is good and powers scanner just wont communicate properly. I have fuel to the filter on the top of the motor and it pressures up.
Old Dec 29, 2009 | 12:04 AM
Chvyrkr's Avatar
FIMC/PCM possibly, if you can't communicate and you're gettin power to the scanner.
You lost something electronic.
Old Dec 29, 2009 | 12:06 AM
thats what iam thinkin
