04 chevy 2500hd cummins conversion
Old Dec 25, 2009 | 12:25 PM
72chevycamshaft's Avatar
Default 04 chevy 2500hd cummins conversion
Great forum guys!!! I was surfing the net looking for conversion help and I found this great forum. I didnt realize that so many people are actually putting a cummins in bowties. Ive wanted to do this to my hd for some time. I do need some help from you conversion experts in here. My pickup is 04 chevy 2500hd 4x4 6.0 5spd. Can I keep my 5sp tranny in the truck? Are there bell housing conversions out there? What years out of dodge are the best to use?
Thanks,
Cameron
Old Dec 25, 2009 | 02:01 PM
someday cummins swap's Avatar
if i remember right it should be a nv 4500 5 speed so you'd just need the input and bellhousing off a nv4500 off a cummins 5 speed depends on the cummins tho 12 or 24 valve i'm not exactly sure tho other guys will be able to help more
Old Dec 25, 2009 | 04:03 PM
FastCR's Avatar
not sure what trans you have in there, but you can get an adapter for damn near anything, or just get an nv4500.
but why isn't it a dmax in the first place
Old Dec 25, 2009 | 06:29 PM
screaminseema's Avatar
The transmission is a ZF-5 speed. You can retain the manuel transmission set up, but you will need to convert to a Ford ZF-5 or dodge nV4500/5600. If you use the Ford ZF-5, you will need to get the adapter and flywheel spacer from Destoked. The hole in the floor will need to be modified as well due to the relocation of the trans/transfercase rearword about
4". The reason you won't be able to retain your GM ZF is because there isn't enough room for the larger clutch diameter/surface area that the Cummins will need.
Old Dec 27, 2009 | 02:45 PM
What would you recommend the Ford ZF-5 or the Dodge nv4500/5600? What year of the 5.9 are the better years? Have you had any probs with your 05 chevy cummins swap with the frame or firewall?
Thanks,
Cameron
DieselDan370
Aug 23, 2016 02:24 PM
Mar 27, 2015 07:20 PM
Chummins80
Feb 28, 2015 08:34 PM
Feb 5, 2015 12:10 AM
gixxerman1000
Nov 2, 2014 07:53 PM
