Died & Doesn't Restart
Old Dec 9, 2009 | 11:47 AM
99stackedpowerstroke's Avatar
Default Died & Doesn't Restart
im having problems with my 99 powerstroke, the other day she just shut down and wouldnt start so i checked all the fuses and none of them are blown, ive even replaced the cam positioning sensor and it still wont start, ive had it started off of break cleaner and ether, any ideas anybody?
Old Dec 9, 2009 | 12:27 PM
wildbill's Avatar
Run a test on the charging system and let us know the results.
Old Dec 9, 2009 | 12:42 PM
have done it the batts are good and the charging system is charging correctly.
Old Dec 9, 2009 | 01:24 PM
wildbill's Avatar
Did you check the HPOP pressure and or oil level??
Old Dec 9, 2009 | 01:29 PM
oil is good, but i have not checked the hpop, how would i check it?
Old Dec 9, 2009 | 06:12 PM
CSIPSD's Avatar
When cranking does the RPM gauge register?
DO NOT USE ETHER with the glow plug system working. You can and will blow the heads right thru the hood.
Are you getting any smoke out of the tail pipe when cranking?
What are your temps right now?
What mods have you done to the truck?
Old Dec 9, 2009 | 06:37 PM
blk99's Avatar
if its cold out, the fuel might be gelled a little.... enough to not start itself... i know the Perkin and the IDI are gelled BAD right now... got Diesel 911 in the PSD...
Old Dec 9, 2009 | 07:18 PM
the only thing ive done is cold air intake programer and the stack, im not getting any smoke, my tach is moving and the fuel shouldnt be gelled ive had it plugged in none stop.
Old Dec 9, 2009 | 07:41 PM
Chvyrkr's Avatar
Any oil in the valley?
Old Dec 9, 2009 | 07:49 PM
nope
