Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
Difficulty Starting 6.0 Powerstroke Diesel
Old Dec 8, 2009 | 10:16 AM
PDubb's Avatar
Default Difficulty Starting 6.0 Powerstroke Diesel
Alright, I just joined DIESELBOMBERS today. Before buying my 6.0, I have always owned a gas operated engine. I purchased my vehicle with 113k miles, and before purchasing the truck I had an OASIS report done and the only warranty work done was a replaced alternator. I bought a 5" Turbo Back Exhaust, 6" lift, put 35" Hankook MT's, new wheels and a SCT SF3 programmer with custom tunes from Elite Diesel. I am now at 159k miles and have noticed a few issues.
First, I should say that originally I was taking my truck to the local lube house to get my maintenance done, but for the past 8 months I have been doing it myself. I change the oil every 5k-6k miles, the fuel filter between every 12k-14k miles, and service the lube points accordingly. I have never really been a motorhead, but I would like to believe I am learning.
I have the SCT SF3 Tuner, but currently my truck is returned to stock. Primarily because I am timid of screwing up my engine which so many folks have warned me about. They are saying the the 6.0 can't handle the tuners. I don't know if that is true, or not. I just don't know enough about it.
My truck has some very weird things happening. The first start is usually a little rough. The first start of the day the truck starts up quickly, but it will run rough for a few seconds, no smoke out of the exhaust. The truck runs well, accelerates well, and getting around 16-17 on the hwy. Once I shut the truck off, to go into the store, or perhaps see a customer, the next time I turn the ignition, it seems to want to start very sluggishly. It doesn't seem to fire immediately!! First I thought to add a fuel stabilizer, injector cleaner. Then I changed the fuel filter and oil. Then I read about replacing the EGR Valve, so I did it. I loaded a tune back into the PCM and it starts fine, but once I return it to stock the same problem. I check the batteries and they are reading 12.75 VDC. Could it be my fuel pump? Could it be my starter? Could it be what they call stiction on the injectors? I am at a loss here folks. No DTC codes and the truck runs fine, besides the start up!!!! It's driving me crazy, because I cant figure it out. Any help would be greatly appreciated. Thanks
chrispowerstroke09
Oct 10, 2015 12:04 PM
BeastFromTheEast
Sep 14, 2015 02:25 PM
BeastFromTheEast
Aug 4, 2015 10:06 AM
irozchris
Mar 14, 2015 11:16 PM
