Airdog II Install Questions
Old Dec 8, 2009 | 06:20 AM
jfoose's Avatar
Default Airdog II Install Questions
I recently got my gauges, smarty and airdog 2 in! Thanks Lucas. Just had a quick question for anyone who has an airdog and the fs2500 underhood kit. It appears that the fs2500 (mounted in the engine compartment over the CP3 using the fs2500 supplied bracket) might be too close to mount the airdog CP3 fitting. Has anyone with the fs2500 installed put the airdog 2 on as well? If so, did you have to move the fs2500 cannister anywhere? Any thoughts would be helpful before I start attacking the project. Thanks guys!
Seriously, not one bomber has this combo, or has any comments?? Ok then, guess I've stumped an entire forum...
Old Dec 8, 2009 | 09:15 AM
1SlowFormula's Avatar
I am hoping to have the same, or similar depending on your outcome, setup this coming spring. Best of luck finding out if it will work, it would suck to get halfway through the install and find an issue...
Old Dec 8, 2009 | 09:19 AM
jfoose's Avatar
I will post something up here when I figure out what needs to be done. There is some wiggle room in there, so I should be able to figure something out. Thanks for the reply!
Old Dec 14, 2009 | 11:17 AM
jfoose's Avatar
1SlowFormula, I had to put a small spacer in the FS2500 mounting bracket to clear the airdog / CP3 connection. I will post some pics when I get a chance. Ended up being about a one inch wide steel block drilled same as filter, then used longer 2 or 2 1/2 in bolts. Can't remember it was pretty late saturday when I got out of there.
Old Dec 14, 2009 | 12:21 PM
thanks for the follow-up, I'm glad it was an easy work around...
Old Dec 14, 2009 | 12:28 PM
12vcummins96's Avatar
thats awesome glad you got it figured post some pics so people who have the same problem will be able to figure it out to
Old Dec 14, 2009 | 02:14 PM
handymanherb's Avatar
Banned
https://www.dieselbombers.com/5-9-li...-part-1-a.html
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
