vacume pump
Old Dec 5, 2009 | 08:38 PM
streetrod's Avatar
Default vacume pump
i have a 200 dodge and am having trouble removing the vacume/power steering pump i have removed the 4 bolts that hold it into the housing but can't get it out what have i missed?
Old Dec 9, 2009 | 12:14 PM
wildbill's Avatar
Can someone help him.
Old Dec 9, 2009 | 04:46 PM
blkjack's Avatar
Its been awhile since i have done one but im thinkin that the gear is bolted to the pump drive or is pressed on just cant remember how it is for sure sorry not too much help on a definate answer but i belive it is one or the other.
Old Dec 11, 2009 | 10:36 PM
wildbill's Avatar
Please update.
Old Dec 13, 2009 | 04:13 PM
USAFGopherMike's Avatar
Yes please. I'm about to do this as well.
Old Dec 13, 2009 | 04:36 PM
00' Quad Cab's Avatar
Mine I pulled right out the gear case, no need to pull the gear, but if someone has messed with it before it may have gasket glue of RTV on it making it hard to pull out.
Old Dec 15, 2009 | 11:19 PM
wildbill's Avatar
What did ya find out??
Old Dec 16, 2009 | 04:29 AM
nate379's Avatar
Isn't there a bracket that goes on the block as well that is kind of hidden? I am trying to remember for sure, it's been a few years since I had one off.
Did you remove the oil line for the vac pump?
Old Dec 17, 2009 | 09:34 PM
streetrod's Avatar
well therre is a bracket on the back of the pump if you get it far enough off the ground that the suspenchion sags you can see it if you have someone else turn the wheel you can see ti but not easy to get to and then the pump removed easly guess next time ill have to look closer found it on a budys holist and problem solved
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
greenbomb
Jan 23, 2015 10:36 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
