Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
07 chevy head unit ?'s
Old Dec 4, 2009 | 05:47 PM
cumminsdad08's Avatar
Default 07 chevy head unit ?'s
hey all,
i got an 07 chevy 2500 gasser for a work truck, and the am/fm radio HAS TO GO!!!!. i spend more time in this thing then i do my dodge, so i finally figured that its time to get a little more comfortable. this has been buggin me since i got the truck 2 years ago. my questions are:
do they make a direct plug in wire harness for these new styles?
do they make a nice mounting kit that is easy to install?
also, do we have a dealer that sells audio stuff on here?
there are a bunch of "local" places that i am sure can do this stuff for me, but i don't really want to get a whole lota cash into this. it does not need to be a "fancy" unit, just plays cd's for me. i have put units in before, but not on anything this "new". i know they make direct plug in harness for older trucks, but what about the new ones. any help would be great. and anyone with some pics of the newer style (07 up) chevy that has done this would be great!!!!!
Old Dec 5, 2009 | 12:19 AM
PSD Interceptor's Avatar
This is for a standard radio system in a 2007 Silverado
Metra Electronics - Products
2007 Chevrolet Silverado C2500 Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/a
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Old Dec 5, 2009 | 06:31 AM
all right now next question, could i just find a factory cd player and drop that in. i have seen somewhere that you need to get a code for it to work. it looks like it will be expensive for a direct plug in wire harness, because of some device you need so the dumb onstar will work for the harness and the mounting kit they want 130-180 bucks. i don't really want to spend that much on someone elses radio.
Old Dec 6, 2009 | 12:17 PM
94Matt's Avatar
My first thought is swapping in a factory one. I don't know your work situation, but I can tell you I would be less than pleased if one of my guys swapped in a cheap radio but a factory one I would probably never notice. You should be able to get a new takeout pretty cheap.
Old Dec 7, 2009 | 04:10 PM
yeah i saw them for cheap, and my boss don't care much, we can perty much do what we want with in reason. we keep the trucks till they die anyways, then bring them back to life, then run them some more. eventually sell them for scrap. my only concern with a factory swap is if the codes will give me a hard time. i don't really want to give a dealership more money then i have to.
Jul 24, 2015 09:30 AM
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
Jmohr52
Feb 8, 2015 10:39 PM
Adam65
Jan 9, 2015 11:50 PM
Oct 16, 2014 07:10 PM
