Off Roading Diesel Discussions of Off Roading , Set Up , Designs , Practices , Techniques , Tips Including Trail Riding , Rock Climbing , Mud Bogging And More
1 or 2 piece driveshaft
Old Dec 3, 2009 | 02:29 PM
FastCR's Avatar
Default 1 or 2 piece driveshaft
Posting in here to get input from all brand camps. My driveline flew apart while I was driving down the road and I need a new one. My best guess is the carrier bearing somehow failed and caused the whole thing to just start whipping around.
I can get another 2 piece from the junkyard from around $100-150 just like the one I had
or
I can get a Tom Woods 1 piece made for $350. Keep in mind I don't really have the money for this option and I'd have to come up with it, but I'm wondering if anyone has experience with going from 2 to one piece or an opinion on the matter. My angle is pretty harsh which is why I haven't gone to a 1 piece yet, and I'm not sure if I'm better off staying with a 2 piece or going to a one piece with harsher angles.
If I get the one piece I'm going to tilt the motor/trans back a bit and probably shackle flip the rear to help out a bit, but in the end its still a pretty good angle.
Old Dec 3, 2009 | 05:10 PM
tltruckparts's Avatar
my best results ive found with these is a one piece thick driveline. get the rear axle assembly at the exact same degree as the driveline, than convert the front to a cv. also takes out the vibration. but most shops wont make a one piece driveline anywhere over 70" or so
Old Dec 3, 2009 | 05:33 PM
FastCR's Avatar
thats what i figured but the shop i use who gets a discount with tom woods said I could get one. its gonna be right around 79"
Old Dec 3, 2009 | 06:40 PM
wildcat's Avatar
Have you measured or had your shop measure your truck for a one piece? They should know if it'll work or not...
Don't know what you are driving, but perhaps a step up to 1410 yokes and joints would help?
Old Dec 3, 2009 | 08:13 PM
FastCR's Avatar
i haven't measured it exactly yet, because if i decide to go with the 1 piece I'm going to do the shackle flip to bring up the pinion angle and drop the *** of the trans about an inch.
It'll be between 74 and 78 inches if I do the changes.
Old Dec 5, 2009 | 07:58 PM
i went through that same process as you with the 12 valve cummins in the chevy. mine is an extended cab long bed i went with a 2 piece stock chevy and shortened the shorter side by 2.5" inches and it fit right in with new u joints. i also have a shackle flip on my truck as well
CumminsCoalRoller24/7
Jul 5, 2015 06:30 PM
casper83
Jun 29, 2015 07:37 PM
CumminsCrazed
Feb 24, 2015 10:11 PM
5.9sledhead
Price Quote - Request A Price
Jan 26, 2015 03:19 PM
