diesel bronco help
Old Nov 30, 2009 | 07:12 PM
BigB's Avatar
Default diesel bronco help
hi i am thinking about doing a ford bronco engine sawp. i want to put a 6bt cummins motor in in and need info and help on the conversion. first off would the engine even fit and if so how hard or what type of modification am i looking at? also if the engine was in would the stock suspension and axles be able to handle the weight and power of the diesel? if i did need an axle swap what axles wood i go for i was thinking dana 60s. what other mods would i hav to do to make a durable diesel bronco, drive shafts, suspension, gearing ect. thanks for your help oh and the bronco year would probly be between 92 and 98
Old Dec 1, 2009 | 04:57 PM
Queeg's Avatar
i dont know about the bronco. but i have seen it done with the ramchargers
looked awsome and he got even better mileage
ill try to dig up some info for you
Old Dec 1, 2009 | 05:13 PM
ArizonaRedneck's Avatar
welcome to diesel bombers bigb
Old Dec 1, 2009 | 05:16 PM
2500HeavyDuty's Avatar
/me moved here
Old Dec 1, 2009 | 05:30 PM
24v'd_Fury's Avatar
I'd go for dana 60's at least. those year bronco's had weak axles. Are you looking to wheel it? If so the gearing would be mostley based on tire size. The good thing is that with the torque the cummins has you may be able to go higher of gears and still "crawl" unlike the gasers.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
