2001 f-350 boost\egt issue
Old Nov 23, 2009 | 04:23 PM
pepe's Avatar
Default 2001 f-350 boost\egt issue
i have a 2001 f-350 that now has low boost pres\ higher egts.injectors were replaced,has cold air,exhaust,intake,chip,helix.use to dump pres under heavy loads now doesn't just engine light comes on,1211 icp pres above\below desired, not controllable.is it the turbo \wastegate spring any ideas?
Old Nov 23, 2009 | 04:38 PM
wildbill's Avatar
Sounds like a waste gate problem, or a leaking boot or boots.
Old Nov 23, 2009 | 09:25 PM
CSIPSD's Avatar
Sounds like your ICP sensor is leaking oil or bad. Or the chip you are running is asking for too much ICP at lower ranges. It has nothing to do with the turbo.
What are your max boost readings?
Old Nov 24, 2009 | 09:30 AM
Deputydog's Avatar
I agree with CSIPSD..
Old Nov 25, 2009 | 10:40 PM
pepe's Avatar
max boost is now between 15-20 on a long pull.it use to make 27-28 easily. but like i said now kicks on the engine light even on the flat. egts are now higher without the chip under normal driving. not good
did try icp sensor, didn't change.egts higher running it stock.it also doesn't start as well as it use to,stock or chiped even after injectors,but not all the time.compression,oil press.,fuel press. all really good.something just not right??!!!!
Old Nov 26, 2009 | 12:59 PM
CSIPSD's Avatar
Who replaced the injectors? what type are they? New o rings all around I assume?
Old Nov 26, 2009 | 03:23 PM
pepe's Avatar
stock injectors through ford. issue was still present before but is more prominent now.installed chip today and tried different things. if i get hard on the throttle it goes flat but if i back off alittle ,the boost press climbs and it pulls hard again.i'm pretty sure it is the wastegate assembly/turbo.looking into a high tech turbo, any feedback on them?
Old Nov 27, 2009 | 12:38 PM
CSIPSD's Avatar
Its NOT the turbo... you have a ICP pressure issue of some kind. Be it a bad o ring, bad IPR or bad icp sensor.
Turbos do not work sometimes and not others...
Need to get some kind of scanner on it, check the ICP pressure and IPR duty cycle while driving
JoeyMiR
9
Feb 3, 2018 10:05 PM
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
899ccs
Jun 6, 2015 01:29 PM
octopusmotor
Mar 19, 2015 02:22 PM
Oct 23, 2014 08:10 AM
