rotary or p-pump???
Old Nov 23, 2009 | 10:20 AM
12v swapper's Avatar
Default rotary or p-pump???
okay guys, here what im doin. swappin a cummins into my ford. so far not so bad findin info and parts. now is the critical part, which 12v rotary or p-pump. i tow(alot) about 16k with this truck. its my daily driver and basically do all rig. i have read about the p-pumps qand how easy it is to get power. also have read about the rotary's and how easy to turn them up. im shootin for 300-350 hp and decent mpg's. i have a e4od that i will rebuild to handle the power. just not sure wich moptor is easier to get power i want.
Old Nov 23, 2009 | 11:03 AM
94Matt's Avatar
Either one will work fine for the power level you want.
Old Mar 16, 2012 | 11:44 AM
duey's Avatar
dieselconversions.com sure helped me a lot with mine. 406-755-8878. They will have all sorts of info for you.
Old Mar 16, 2012 | 02:37 PM
94cummins12v's Avatar
ppump without a doubt
Old Mar 18, 2012 | 10:00 PM
Whargoul's Avatar
Banned
Either or. Both are fine for your needs.
Old Mar 26, 2012 | 03:29 PM
EasternAggie's Avatar
If 300-350 is all you want, a rotary VE or inline P7100 should get you there easily.
Old Mar 26, 2012 | 05:34 PM
tiremann9669's Avatar
Thats like asking hamburger or steak, both are good but ....
Old Mar 26, 2012 | 05:56 PM
I don't understand. If all he wants 300-350 hp for a DD/tow rig (and will probably doesn't need to run over 3k RPM), what advantage is the P7100 going to give? The VE starts quicker, has more low end torque, has dynamic timing, and fuel mileage is usually a tad bit better with them.
I'm not knocking the p-pump, I searched hard for one, but my truck will eventually be at 5-600hp; it suits my goals better.
Old Mar 26, 2012 | 06:13 PM
moparbubbabt59l's Avatar
The ve has my vote. Fast starts dynamic timing better low end fueling
Sent from my DROIDX
Old Mar 26, 2012 | 07:09 PM
deck60's Avatar
either will get you what you need and I think you can get the p pump to start just as good as the ve
its all in the heads before I had my head gasket go out on my p pump it would start hard the guy that did my head work really understood how to grind valves on a diesel and now it starts as good or better than our 91 ve
