Rear Axle Blocks
Old Nov 19, 2009 | 04:00 PM
BD Cummins's Avatar
Default Rear Axle Blocks
I just put 3500 rear leaf springs on my 2500, now the *** end sits really high and i was wondering if anyone had ever cut the rear blocks down and everything still lined up right, or if anyone knew the deminsion of 1500 rear axle blocks.
Old Nov 19, 2009 | 06:39 PM
Uncle Bubba's Avatar
ICSmoke/Ian cut his axle blocks down to drop his truck. The only difference between the 2500 and 3500 springs on diesel equipped trucks was 1 extra spring on each side. The gasser 3/4 tons come with a smaller spring pack.
Old Nov 19, 2009 | 09:38 PM
BD Cummins's Avatar
ok so if i just machine my blocks down i shouldnt have any problems? is there anything i need to watchout for when cutting them down or just make a nice straight cut
Old Nov 19, 2009 | 09:43 PM
Not that simple cause they aren't flat. They have contours to them to hold them in place better. Here's Ian's thread, it may give ya some idea's. Or PM him.
https://www.dieselbombers.com/tire-w...cs-inside.html
There should be a short block in there that's a little over an inch tall that you could just pull out all together. Don't know what kind of difference your wantin to make here.
Old Nov 19, 2009 | 10:28 PM
BD Cummins's Avatar
ok thank you
Machinist
Jun 23, 2015 06:57 AM
Natenelson1
Jan 19, 2015 07:23 PM
Dec 19, 2014 02:30 PM
natenel1
Oct 26, 2014 03:09 AM
94cummins12v
Towing and Hauling
Oct 21, 2014 02:50 AM
