ehh got some codes
Old Nov 18, 2009 | 10:36 PM
CumminsTurbo22's Avatar
Default ehh got some codes
here they are
P1652 J1850 Communication Bus
and P0480 witch is the fan
How do i cure this problem?
thanks
Nick
Old Nov 19, 2009 | 05:17 AM
Whit's Avatar
Site Mascot
If yer not over heating I would just clear them and see if they come back
Old Nov 19, 2009 | 07:42 AM
wildbill's Avatar
P0480 = Fan clutch
Possible Causes:
FAN CLUTCH
WIRE HARNESS DAMAGED
OPEN FAN CLUTCH (K160) DRIVER CIRCUIT
(K160) DRIVER CIRCUIT SHORTED TO (K690) RETURN CIRCUIT
(K160) DRIVER CIRCUIT SHORTED TO BATTERY NEGATIVE
INTERMITTENT CONDITION
ECM
P1652 = J1850 Short to ground
Possible Causes:
ECM
(D25) J1850 SHORTED
COMMUNICATION
So it's possible the ECM is bad. Still under warranty??
Attached Thumbnails ehh got some codes-fan-clutch.jpg   ehh got some codes-fan-clutch-ii.jpg   ehh got some codes-j1850.jpg   ehh got some codes-j1850-ii.jpg
Old Nov 19, 2009 | 09:50 PM
No warranty... i cleared the codes and havent seen nothin yet, ill see 2mrw if it pops up again, No CEL light just the code when i do the key cycle. if it does, ill go through your post bill. Thanks guys
Nick
Old Nov 20, 2009 | 11:10 PM
wildbill's Avatar
Sounds like a small electrical gremlin. If it was the ECM, CEL would be on all the time, along with a funky running truck. Code popped up, but cleared the CEL itself. So what ever happened, it fixed itself. Just for stored codes now is all.
Old Nov 25, 2009 | 07:00 AM
ok well just getting the p0480 code still, cleared it and it stayed off a few days. then checked the codes again and it poped up. Ill look for harness to see if the wires were cut.
I do have another problem as well, my speedo is sticking. could it be dirty inside? looks clean but maybe the last owner was a smoker and the gunk is affecting the needle. any ideas?
Old Nov 25, 2009 | 04:03 PM
wildbill's Avatar
It's sealed pretty tight. Only thing I can think of is a faulty ECM.
Old Nov 28, 2009 | 01:18 PM
wildbill's Avatar
Updates??
Old Nov 29, 2009 | 01:56 AM
sorry been really busy, havent checked the harness yet. i will tomorrow tho
Old Dec 2, 2009 | 08:17 PM
wildbill's Avatar
Updates??
