K&N OIL filter?
Old Nov 13, 2009 | 05:39 PM
REDRIDE13's Avatar
Default K&N OIL filter?
Anybody used a K&N oil filter before? Are they worth the extra $$$$ I Like the wrench on Idea.
Old Nov 14, 2009 | 02:16 PM
Deezel Stink3r's Avatar
Ok, after using it several times I stopped it. The built in wrench thing isn't worth it.
Because I have a cheap special tool for every oil filter.
After knowing that the german military has tested the K&N filters and they failed due to bad fine filtration I can't see any advantages. Good brands are priced like the K&N and I don't need any safety wiring on an oil filter.
I really think about switching to additional bypass filtration.
Fine dirt and dust particles around 5 micron aren't caught by the main filter. the main isn't able to catch particles less than30 microns.
But these fine, small particles do the most damage to piston ring and turbo bearings.
I don't go for extended drain intervals, I just want to cut down the amount of fine particles.
I have seen a lot of semis having that bypass filtration or having an oil centrifugal filtration system. I think fleet maintenance has already learned to avoid early engine damage.
Why shouldn't I do the same?
I also kicked out my K&N Air Filter- I stick now with the stock air filter again.
Old Nov 14, 2009 | 05:23 PM
I would stay away from K&N also. Stick with the OEM filter. or go to an Amsoil bypass setup.
Old Nov 22, 2009 | 02:30 PM
440ctd's Avatar
I use baldwin filters that are carried at the local truckpro or sometimes if I can't make it there then ill go to autozone for stp or whatever they have decent
Old Nov 22, 2009 | 03:08 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i am running afe oil filters and royal purple in my 08
soco
Jul 27, 2015 06:06 PM
helton87
For Sale
Jun 3, 2015 02:36 PM
Bob V
Apr 6, 2015 11:02 PM
jhprice
Mar 29, 2015 09:36 PM
Moparpower440
Jan 24, 2015 06:58 PM
