what programmer for this setup?
Old Nov 12, 2009 | 12:54 PM
jake 94's Avatar
Default what programmer for this setup?
gettin a 98.5 cummins reg. cab long bed 5 speed with 180k with Dynomite Diesel injector pump, Walbro 95gph transfer pump, EGT,Fuel press, Boost Gauges,RV 275 Injectors, 5" exhaust w/Donaldson 5" muffler. What would be the best programmer for this setup and what would i be puttin down for hp/tq with the setup?
Old Nov 12, 2009 | 01:06 PM
Shea@L&N Performance's Avatar
FormerVendor
Id go with a edge drag comp and if you got a lil extra money stack a smarty with it. Lots of factors go in for getting rwhp. If you still got your stock clutch it wont last long with this setup, and you might also want to step up to some bigger injectors and a turbo.
Old Nov 12, 2009 | 01:26 PM
nbaca's Avatar
i vote for a quad adr with pulse
Old Nov 12, 2009 | 01:55 PM
Quadzilla Adrenaline
Edge Juice with Attitude
Edge Comp
Old Nov 12, 2009 | 02:18 PM
Wyatt Earp's Avatar
Edge COMP with Smarty Stack. Trouble is you will likely see issues with your turbo.
HotRodCrewCab's Avatar
I have the adrenaline... never had any issues with it and it makes plenty of power. Ive never tried an edge box so I cant give any opinion there
Old Nov 12, 2009 | 05:57 PM
1st_gen_puller's Avatar
I've had the edge comp/smarty stack.. rode in similar truck with quad adrenaline and pulse.. i vote quad..
Old Nov 12, 2009 | 07:40 PM
tdiezel's Avatar
I vote quad adrenaline as well unless you are going for real big HP gains then you want the other two stacked.
Old Nov 14, 2009 | 01:33 PM
jake 94's Avatar
so if i do those two stacked ill need to get a turbo and clutch?
Old Dec 4, 2009 | 03:14 PM
lobsterman04's Avatar
If youand when you get a pressure box(chip) you will NEED a turbo and clutch. Took me 3 weeks to completly fry a stock torque convertor with the adr and with the stock turbo and whats in my sig i once very briefly saw 1800*
JPatt
Jul 29, 2015 03:25 PM
vinnie0104
Jul 6, 2015 03:55 PM
klu408
Apr 26, 2015 07:52 PM
ForrestB
8
Mar 4, 2015 08:53 AM
aoutlaw95
9
Jan 5, 2015 07:21 PM
