2006 6.0L No Start
Old Nov 11, 2009 | 08:38 PM
RBeach's Avatar
Default 2006 6.0L No Start
I got a 2006 6.0L 140,000 miles; the first two warm starts this morning took longer than usual, took around 5-6 sec to fire up. Later on that morning killed it to fuel up, and would not start, will turn over but no start. Computer not showing any codes, no check engine light, oil pressure gauge not moving when engine turning over. Trying to get some input before taking it to dealer
Old Nov 11, 2009 | 08:55 PM
dslack's Avatar
Default No start
I may of had the same problem last Dec. My 05 f350 would only start when cold, stop for fuel etc. I had to wait 20 -40 min. before it would fire. It would crank all day but not fire.
Took it to the dealer diag. was the internal high pressure oil pump. Appox. $2000.cdn.
ds
Old Nov 11, 2009 | 09:29 PM
RBeach's Avatar
Yep, kinda what I was thinking after some research. My truck has been running rough when cold to the point that it isnt driveable until engine would reach normal operating temp. That problem has been going on since around 100,000 miles. I tried running some oil additive (Hot Shot's Secret) they claimed it would clean injectors and improve cold starts. I could not tell a difference. Did you have any trouble with cold starts before your HPOP went out?
Old Nov 12, 2009 | 02:11 PM
oshp129's Avatar
I am dealing with the hard start problem right now, so far (1st day) they told me the batteries were bad, yet they had 48 volts coming out of the ficm. Several people here have told me the ficm may be going bad. The dealer does not have a clue.
Good luck, keep me posted.
Old Nov 12, 2009 | 06:44 PM
smokincummins92's Avatar
I replaced a hpop in an 03 but it ran fine when cold, it would cut off when it got up to operating temp.
Old Nov 13, 2009 | 05:12 PM
bobfbigman's Avatar
Default quick connect fitting on pump
Keep in mind 05 and newer have a diferent pump and fittings than the 03-04 trucks, most of the problems with the 05 truck is just the quick connect fitting /$50/ on the pump. My sister's truck had the same problem and she took it to a dealer, quoted her $4500 to replace pump oil cooler and egr cooler, I fixed it for $225 in about 8 hours, that included a egr block off kit as well. plus I took the time to clean out the intake, I doubt they would do that. The telltale sign is the truck will start cold but not hot, let it cool down for an hour or so it will start, that is the quick connect fitting, if the pump was bad it wouldn't run at all or very poorly all the time,Bob
Old Nov 14, 2009 | 02:29 AM
wildbill's Avatar
Weekend bump
Old Nov 17, 2009 | 09:13 PM
wildbill's Avatar
Updates??
Old Nov 21, 2009 | 02:21 PM
wildbill's Avatar
Closing thread due to inactivity.
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
HKLBRY
Feb 18, 2015 09:46 PM
HKLBRY
Feb 17, 2015 08:52 PM
makuloco2000
Feb 15, 2015 02:31 PM
