04.5-05 LLY Performance Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines Related To Performance And Longevity
Pics of blade runner installed
Old Nov 10, 2009 | 08:24 PM
jlawles2's Avatar
Default Pics of blade runner installed
I installed the blade runner today (finally). Attached are a couple of pictures. I also rerouted the PCV while at it. Used a boat plug from the hardware store. I pinned both of the plugs after using loctite on the threads (can never bee too safe when parts can fall into the turbo inlet).
Attached Thumbnails Pics of blade runner installed-pb101944.jpg   Pics of blade runner installed-pb101945.jpg   Pics of blade runner installed-pb101946.jpg   Pics of blade runner installed-pb101947.jpg   Pics of blade runner installed-pb101948.jpg
Old Nov 10, 2009 | 08:30 PM
jlawles2's Avatar
More pics.
Attached Thumbnails Pics of blade runner installed-pb101950.jpg   Pics of blade runner installed-pb101951.jpg
Old Nov 10, 2009 | 08:34 PM
2500HeavyDuty's Avatar
i did not know afe even made such a thing, how is the 90* transition, anything can be better than the stock LLY one
Old Nov 10, 2009 | 09:03 PM
jlawles2's Avatar
The 2nd pic shows how they address the 90*. Along with the vanes, anything is better. I will keep you informed on how it runs as I did not have time to test drive tonight.
Old Nov 10, 2009 | 09:07 PM
if u had efi live u can measure the ammount of air being sucked in and would be able to see how much of a gain it would be
Old Nov 14, 2009 | 07:34 PM
jlawles2's Avatar
After driving for a couple of days, it seems to spool faster. Not much gain by the seat of pants dyno. The EGT's on the other hand do seem to be better. Particularly when at idle just before turning the motor off. The EGT's seem to drop below 400 in about half the time as before. The EGT's do not seem to hover at the 410 mark for several seconds, instead they drop steadily down to the 360 mark then hover and continue to drop after that. I usually turn the motor off after the EGT's get under 400.
Callmecowboy
Jun 27, 2015 04:30 PM
BIG SOCHA
Oct 23, 2014 11:01 PM
