air in fuel?
Old Nov 7, 2009 | 05:34 PM
MM1SSDV's Avatar
Default air in fuel?
I have an 89 IDI hard starter. I purge air from system, it finally starts, runs, drives. I let it sit overnight. The next day It starts, runs for ~5 seconds, stalls, and I repeat the cycle. I do get bubbles from the fuels filter schraeder valve. I crack the the lines to all of the injectors. Should I buy an up pump? If so, how to wire it? The saddle tank had a leak and was removed. I'm hoping I won't have to drop the aft tank. So far I bought it for $1800, Used motor for $4800 & have not been able to make any money with it yet.
Old Nov 7, 2009 | 06:34 PM
wildbill's Avatar
Sounds like the lift pump is leaking back.
Old Nov 11, 2009 | 12:03 PM
wildbill's Avatar
Closing. Thread starter can reopen.
Dbleo351
Nov 20, 2016 09:34 AM
jeffersonl
Nov 15, 2015 07:35 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
