Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
DIY 2nd gen oil/fuel change
Old Nov 5, 2009 | 01:02 AM
biged681985's Avatar
Default DIY 2nd gen oil/fuel change
here is my DIY service
first off, i pulled the plug and drained the oil
my oil pan uses a 10mm alanhead. pull the plug, be sure not to drop it in the oil pan, especialy if the oil is hot. certain pans, if u drop it into the pan, it will block the hole and cause it to over fill.
next, while the oil is draining, i go ahead and pull the air intake tube off, this is not nessecary, but does make it easier to get to the fuel filter.
then i pull the filter off, and make sure the rubber gasket comes off with it
then i take and fill the new oil filter up completly
and put fresh oil on the new rubber gasket
then myself, i write the milage down on the filter
then put the new filter on tight
next i put the air filter tube back in
then i put the oil filter plug back in
then i fill the motor with oil
then i start the truck, check for leaks, shut it back off and check the oil level
Old Nov 5, 2009 | 01:08 AM
then for the fuel, mine has airdog filters.
i removed the water seperator firts, started off draining them, then the fuel filter
then i put the new filters on
and put the milage on them
then i put the next oil change sticker on
Old Nov 5, 2009 | 01:12 AM
12vcummins96's Avatar
where did u get the d b oil change reminders
Old Nov 5, 2009 | 01:17 AM
from db of course
chad gave them away awhile back
Old Nov 5, 2009 | 01:50 AM
2500HeavyDuty's Avatar
Yeah they were a one time deal, i have a few too
Old Nov 5, 2009 | 06:04 PM
blkjack's Avatar
Needs me some of them DB lube reminders too cool. Also nice usein rotella oil
Planin on doing the same to mine this weekend and also got me a BHAF ordered should be here tomorrow so LOF and BHAF with fabin up a heat sheild fun times bombin great illustrations too nice work ed
Old Nov 5, 2009 | 08:22 PM
i just pulled amsoil out of it, but till i get all the oil leaks fixed, im not puttin that high dollar stuff in it no more gets expensive
Old Nov 7, 2009 | 10:15 PM
Pyro690's Avatar
How bout you tell us how you fix all of your oil leaks? I got a few as well.
dieseldriver626
Aug 22, 2015 08:33 PM
CGwill
Jan 26, 2015 02:10 AM
Cumminsfreak24
Jan 21, 2015 09:10 AM
bigbrowngoat
Jan 7, 2015 06:43 PM
myago92
Oct 17, 2014 08:50 AM
