OIL COOLER END HEADERS CAPS
Old Oct 31, 2009 | 12:43 PM
DRUMMAKER's Avatar
Default OIL COOLER END HEADERS CAPS
HI!,I HAVE A 94 FORD 7.3IDI IN A E350 VAN, OIL COOLER HAS FAILED TWICE IN`65000MI SINCE ENGINE REBUILD.COOLER IS NOT NEW, JUST REDONE WITH RINGS AND GASKETS BY FORD AND OTHER SHOP. AFTER I REMOVED IT I NOTICED SLIGHT WEAR GROOVES WERE THE O-RINGS REST IN THE END HEADERS. I HAVE BEEN SERCHING FOR A SOURCE FOR NEW HEADERS, FORD SAYS NOT AVAILABE. IS THERE A METAL (ALUMINUM) FILLER THAT CAN BE USED TO FILL THESE SLIGHT GROOVES AND THEN HONE SMOOTH?. I WAS TOLD I MIGHT BE ABLE TO USE A COOLER DELETE KIT AND DO AWAY WITH THE PROBLEM, I HAVE SERCHED TO NO AVAIL, CAN'T FIND ANY FOR THIS ENGINE. PLEASE REPLY AS THE VAN SHE AIN'T A MOVING. THANKS
Old Oct 31, 2009 | 01:01 PM
Jet A Fuel's Avatar
do away with the stock cooler and put on a Flex a light cooler similar to an aftermarket trans cooler.The vendors or sponsors here can help ya. Try Tony at Mighty Diesel Mighty Diesel - Diesel Performance Parts For Cummins , Powerstroke , Duramax And More
Old Nov 4, 2009 | 06:02 AM
wildbill's Avatar
Please update.
Old Nov 7, 2009 | 06:37 PM
wildbill's Avatar
Updates please.
Old Nov 8, 2009 | 03:43 AM
91 idi smoker's Avatar
you cannot delete the cooler but the idi and the di powerstroke use the same oil cooler and most guys at parts stores and sadly even dealership parts departments dont kno this because to them if the computer don't show it then they can't get it but you will need to be carefull because the headers are different from the idi trucks to the idi vans but i'm not sure if they did that on the powerstrokes. don't kno if this will help but i hope it does
Old Nov 11, 2009 | 12:05 PM
wildbill's Avatar
Closing due to lack of activity. Thread starter can reopen.
Crabber0001
6.0L Performance
Aug 4, 2015 12:30 PM
tim12valve
May 6, 2015 10:40 PM
Bighouse
Apr 9, 2015 06:51 PM
emilio2496
8
Jan 13, 2015 05:03 PM
bypass-21
Dec 15, 2014 08:52 AM
