98.5-02 Cummins 24V 5.9L VP-44 Tech Talk Tech Articles for the 2nd Generation Cummins 24V 5.9L VP-44 Engines.
P-pump 24v info*
Old Oct 31, 2009 | 10:42 AM
Smokem's Avatar
Default P-pump 24v info*
The 12v injector needs 53psi seat pressure to create 300BAR, the 24v injector needs 32psi seat pressure to create 300BAR. A difference of 0.005" installed height alters the opening pressure 30BAR on the 24v injector. So, to achieve the same rate of the 12v compressioin spring, a 24v injector would need the opening pressure set to ~ 180BAR, and this would soley be a crutch. Needless to say lowering the opening pressure to the common range of 12v injectors being 260-280BAR doesn't even come close. Opening pressure can play into the power that can be made with a certain size nozzle, lowering the opening pressure can lengthen or increase duration therefore increasing the injected quantity. However, this will decrease atomization and efficiencey past a certain point. Response is often better with a higher opening pressure, which is beneficial for a street application, even though the peak number may be a bit lower.
Old Oct 31, 2009 | 10:57 AM
Jet A Fuel's Avatar
1 bar equals one atmosphere or 14.7 Psi for us metric dummys.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
