A 94 cummins what should I do with it?
Old Oct 31, 2009 | 09:58 AM
dieselmissfire's Avatar
Default A 94 cummins what should I do with it?
I just bought a 1994 dodge 2500 with a cummins. I put a pusher elbow, custom intake and a larger exhaust on it. I want it to rev higher and they have spring kits for the pump to do it I was wondering how high can I rev a stock motor and still be safe? I'm going to put in a valve body kit and torque converter. Can anyone else think of what I should do for cheap to make some good performance gains?
thank you
Rob
Old Oct 31, 2009 | 10:15 AM
Whit's Avatar
Site Mascot
a different fuel plate is next to nothing.........but you will need those mods on the auto tranny to hold the power.............a 3 or 4k spring kit will also require the 60# valve springs to do it right
Old Oct 31, 2009 | 04:18 PM
Shea@L&N Performance's Avatar
FormerVendor
Gauges,diff fuel plate or take it out, 4k Gov springs, 60# valve springs, 191 delivery valves, change the timing, injectors and turbo, lots of tuning, you should be doin pretty good, and then you will be ready for a fully built tranny then bigger injectors and a bigger turbo or two
Old Oct 31, 2009 | 05:15 PM
12vcummins96's Avatar
definetly a set of guages also fuel plate adjust the afc and
Old Oct 31, 2009 | 11:15 PM
bowtech's Avatar
if you use just a 3k kit you dont need the 60lb springs every one says if its a daily driver a 3k is fine but its what ever you want
Old Nov 2, 2009 | 08:34 AM
insane3639's Avatar
What tuning is their for a 12 valve cummins?
Old Feb 10, 2010 | 10:50 AM
young gun's Avatar
the valve sprins neveer hurt to have. they'll just hold the valve against the seat tighter holding in compression and the explosion on the powerstroke resuting in more power.
but youre right you don tneed them. if i were you i would start off with guages first, fuel plate(depnding on your trans there are different cuts for better performance) then move your afc forward(this is where the tuning comes in)and do the govenor springs. and if your trans is auto and stock you'll need to upgrade that before you go any further.
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
