VW Diesels Discussion of all things Volkswagen Diesel - TDI, Bug , Touareg , Jetta , Golf , Passat
1998 VW Diesel
Old Oct 26, 2009 | 11:32 AM
vw machine's Avatar
Default 1998 VW Diesel
I dont know if this is where I get info about car issues, here goes. I have a 1998 VX new beetle diesel and it has no power and it blows black smoke. When I step on the go pedal it only revs to 2000 rpm and thats it. Any ideas? welcomed
Thanks
Old Oct 26, 2009 | 12:56 PM
greasemonkey's Avatar
I don't know much about the VW diesels, sounds like a problem with your turbo, though...can you hear if the turbo is spinning? do you have a boost gauge?
Welcome to DB!
Old Oct 26, 2009 | 12:58 PM
Whit's Avatar
Site Mascot
change the fuel filter nad air filter and see how she goes then
Old Oct 26, 2009 | 01:20 PM
Wyatt Earp's Avatar
Black smoke and no power - simple - the inlet has fallen off the turbo giving you no boost, lots of fuel and no power. It has happened to me on my 2003 after a large dip in the road. Not fun to go from 120km/h to 30km/h in 1200m.
So, remove the skid plate or plastic bottom skirting. Look up under the foot well of the passenger and inspect - it will be easy to see. Fix it by ditching the spring clamp and installing a real band clamp that is screwed down.
It may be your MAF and all that other sort of thing too but always look at the simple things first.
Old Oct 27, 2009 | 10:05 AM
zrock's Avatar
sounds like MAF to me seen it way to many times at the dealer. Pull the MAF get some sensor safe intake cleaner and give it a good cleaning be carfull around the tip where the wire is. Somethimes this will fix them if not you have nothing to loose. you can find them fairly inexpencve in the aftermarket
Old Oct 27, 2009 | 10:32 AM
Wyatt Earp's Avatar
On a '98 that is doubtful as if it has been driven hard as it should be and the plastic skid plate is damaged it is likely the plumbing to the turbo is also damaged in some way - much like say an older dodge with a boost leak (cracks etc.).
Anyway, like I said, look at the easy stuff first and get back to us.
Old Oct 27, 2009 | 01:42 PM
vw machine's Avatar
Thanks for the helpful info. Atleast I am headed in the right direction. Ive checked all the plumbing I took the turbo out and checked the bearing. Put it all back together (that was fun). Nothing has changed. Now I am on the top of the engine and going through all of the fuel system up there. What ever I find I will defintely let everyone know what it is.
Old Oct 28, 2009 | 10:54 AM
zrock's Avatar
you may want to check the condition of your timming belt as well... might have jumped if it is old
Old Dec 13, 2009 | 12:50 PM
vw machine's Avatar
Default I fixed it!!!!
Thanks
It was a soot build up in the intake. It was sooo bad I could barely put my finger in there. Thanks again for your info I hope someone can read this before it costs him too much time or $$$.
Old Dec 20, 2009 | 01:11 PM
oldsinner111's Avatar
The killer of VW diesels is the EGR.You can disable by plugging line with a BB.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
JohnFromVt
Aug 3, 2015 06:15 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
