Airdog II with a Edge w/attitude
Old Oct 25, 2009 | 10:31 PM
01trailerpuller's Avatar
Default Airdog II with a Edge w/attitude
I just installed my Airdog II. I have an Edge w/Attitude. I had to run the pump through the stock filter to keep my fuel pressure gauge on my Edge. Has any one come across this problem and have you been able to fix this?
Old Oct 25, 2009 | 11:27 PM
Call me tomorrow and we can set you up with the correct fitting.
Old Oct 27, 2009 | 08:46 PM
sledwrecker's Avatar
summit sells a barbed fitting also that you just put inline and it has a pipe thread fitting in it that the sending unit will screw into. I think it was about $10.
here it is Mr. Gasket 2975 - Mr. Gasket Fuel Pressure Gauge Adapters - Overview - SummitRacing.com
Last edited by sledwrecker; Oct 27, 2009 at 08:46 PM. Reason: Automerged Doublepost
Old Oct 27, 2009 | 10:09 PM
RAW's Avatar
RAW
Why not drill and tap you banjo bolt on the supply line to the VP44? 1/ 8 NTP is all it should be. Should have enough wire harness to reach that far. Cost $0!!
Old Nov 22, 2009 | 07:03 PM
if the air dog is like the fass, then it comes with it's own 3/8 fuel line and has it's own filters integrated into the unit. The design is to totally eliminate the factory plumbing by replacing the banjo bolt on the VP44 witha fitting that the 3/8 line that is supplied with the unit can adapt to.
Old Nov 23, 2009 | 05:04 PM
asabadin's Avatar
does the airdog II 150 eliminate the factory filter?
Old Nov 24, 2009 | 10:38 AM
01quadcab's Avatar
you can get the right fitting to put in your vp with a 1/8 port to hook into. local shop has them on hand for every fass install they do. I just don't know the part number or sizing off hand
Old Dec 1, 2009 | 04:25 PM
I got the part from Airdog it cost me $15 shipped to my house. It is a new fitting to replace the banjo bolt and allow my sensor. Thank you all for your help.
justinsbeck
Jan 18, 2016 12:15 AM
RexShoppe
Price Quote - Request A Price
Jul 11, 2015 01:15 PM
Kfohne21
For Sale
Dec 23, 2014 04:17 PM
somarillw
Dec 8, 2014 09:07 PM
CumminsCrazed
Oct 27, 2014 09:02 PM
