Injection Pump Solenoid???
Old Oct 25, 2009 | 11:53 AM
cwgrl's Avatar
Exclamation Injection Pump Solenoid???
Hi all!
I got a 1984 K3500 w/6.2. Starts fine when cold. When engines is warm won't start. I've been told that it could be the Injection Pump Solenoid. Is this something that can be replaced easily?
Any advise would be great! THANKS!
Old Oct 26, 2009 | 12:31 AM
Queeg's Avatar
i have 2 friends with an 83 and 84 6.2 diesels. and it has happened to both. one was a secondary fuel filter hidden under the aircleaner housing toward the firewall. it was never changed from the privious owner untill we found it on a diagram. not all 6.2`s have them but i haave found a few that the owners never knew they were there. this would caused the exact same symptoms as you described.
how long does the truck sit before you try to start it after driving?
this will also help diagnose more. 5 min, 20, etc..
there are a bunch of people here with 6.2's so be patient and more help will come!
Old Oct 26, 2009 | 11:32 AM
Budgreen's Avatar
air leaking in when things are warmed up maybe?
Old Oct 27, 2009 | 04:49 AM
wildbill's Avatar
Run a jumper wire from the cutoff solenoid to the return solenoid (terminal with 2 green wires). Let us know if that helped.
Old Oct 27, 2009 | 02:08 PM
cwgrl's Avatar
Thanks for the info!!!
The truck varies on start up times, sometimes it can be 15 mins, sometimes up to an hour or so.
The truck doesn't have a second fuel filter I was hoping it was something as simple as that.
Old Oct 27, 2009 | 08:22 PM
wildbill's Avatar
Does it vary to outside temperature or using the block heater?? Could also mean the injector pump is on it's last leg.
Old Oct 30, 2009 | 05:18 PM
wildbill's Avatar
Closing from no updates.
ctjkelley
Jun 3, 2015 06:01 AM
nelly559
Feb 17, 2015 06:49 PM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
