Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
Intake Manifold Change
Old Oct 22, 2009 | 01:02 AM
biged681985's Avatar
Default Intake Manifold Change
i made myself a grid delete out of a 12 valve grid heater/intake maifold combo
first i too the intercooler boot clamp off, then took dipstick bolt off, and moved the dipstick out of the way, then i removed the gir heater wire, and then i took the remaining 5 bolts out of the intake horn.
nect, i removed the injectors, removing all 6 line nuts (19mm) from the pump first, then i took the two intake manifold bolts holding the injector lines in place out (10mm). then i moved to the passenger side, and removed the 6 line nuts (19mm) off the injectors.
next, i removed the rest of the intake manifold bolts (10mm), and removed the manifold
next u scrape the old gasket off the head, (and the manifold if there is any stuck to it if ur reusing it)
(no pic)
then u put the new gasket down, and install the intake manifold and put all the bolst (10mm) into the manidold, that were removed at this stage in removal
next, set the injector line back onto the engine, i always get just a few threads on each one started befor tightinging them all down. then tighten the injector line nuts (19mm). i tighten all down tight besides for injectors #1 and #2 at the injector, to bleed the air out of the lines when starting. then install the two other bolts into the manifold, that hold the injector lines still.
finaly, reinstall the intake horn, tighten all 4-5 bolts (10mm) down tight, then put the dipstick back into position, and install the 10 mm hold down bolt. then tighten up the the boot to the intake horn.
thanks for reading. :cheers:
Old Oct 22, 2009 | 01:22 AM
stkdram55's Avatar
you'd make more power if your valve covers were blue instead of green
Old Oct 22, 2009 | 10:06 AM
so thats my problem, i didnt think it was light of a green when i bought the can, but i wasnt goin to throw the can away, and had to put them back on so, i went ahead and sprayed them
Old Oct 22, 2009 | 12:56 PM
12vcummins96's Avatar
wow that i s baby green
Old Oct 22, 2009 | 08:17 PM
i have plans on a color change most yall witll probably think the same bout it being ugly, but its mine,
caissiel
Sep 24, 2015 05:37 PM
ctjkelley
Jun 3, 2015 06:01 AM
Old12er
Feb 20, 2015 10:35 PM
jrsavoie
Feb 6, 2015 09:44 PM
Finn92
Jan 6, 2015 05:54 AM
