What turbo??
Old Oct 19, 2009 | 08:22 PM
95cumminsguy's Avatar
Default What turbo??
hey guys iv almost got my engine all put back together and its time to start thinking about what turbo I should buy. My engine will have 150 hp injectors, custom fuel plate, 191 delivery valves. Im going to set my timming around 13.5 or 14. What turbo do you guys think would work best with this set up? I dont wanna have major lag because I will tow with it occasionally. But I also dont want my EGT's through the roof either.
Old Oct 19, 2009 | 10:31 PM
12valvetater's Avatar
i hink you need more timing and a 62/71-14 would probly work good
Old Oct 20, 2009 | 07:30 PM
sswing's Avatar
62/68/14 71 too much lagggggg and get ure timing up to 18 - 21
im at 21 and no problems
Old Oct 20, 2009 | 11:17 PM
collinscummins's Avatar
Depends on your setup. I would say run at least 16* timing, if your head isnt O ringed and studded. I personally wouldnt go to much higher than 18* your cylinder pressures get real high after that. As for turbo I would get a 62/71/12 if you plan on towing a lot. You should have plenty of fuel to light it
Also from what i have heard and read the 62/68 surge a lot. The 62/71 is suppose to not surge. So i would go with what I previously stated.
Last edited by collinscummins; Oct 20, 2009 at 11:17 PM. Reason: Automerged Doublepost
Old Oct 22, 2009 | 07:54 PM
K thanks guys, before i tore into my engine to rebuild the timming was at 18 but it kinda ran funny sometimes at WOT so i was going to back it off just a wee but maybe ill bump it back up and see what happens thanks again for the turbo advice
Old Oct 23, 2009 | 07:22 PM
Shea@L&N Performance's Avatar
FormerVendor
I would go with a 62/71/14 or 62/68/13 and put the timing between 16-18. If ya need anything or some help give us a call.
-Shea
Old Oct 23, 2009 | 09:54 PM
xzaq103's Avatar
FormerVendor
-Shea
X2
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
