will it handle it easy?
Old Oct 18, 2009 | 06:20 PM
bowtech's Avatar
Default will it handle it easy?
i have a suncoast vb and goin to get a single billit tc (suncoast) and i have all stock tranni now with the mods i have and it dont slip so when i put the vb and tc in then im goin to add a 5 fuel plate it should handle it just fine right?
Old Oct 18, 2009 | 10:36 PM
rkadcock's Avatar
N.M. Bombers Director
Should. I don't see why it wouldn't considering when I first started getting bombing my completely stock tranny managed to surive with a 5 plate.
Old Oct 18, 2009 | 10:47 PM
bowtech's Avatar
ok sweet now i hust need to get a 5 plate
Old Oct 18, 2009 | 10:56 PM
rkadcock's Avatar
ebay my friend. to bad you didn't post this a day or two ago... I was tuning my AFC and couldn't find my old stock plate so I grinded my 5 to a 0. I would have been happy to have sent it your way.
Old Oct 18, 2009 | 11:54 PM
bowtech's Avatar
thats how it works though. how you tune your afc? whats envolved with it easy?
Old Oct 19, 2009 | 10:05 AM
rkadcock's Avatar
its just a matter of sliding the plate where you want it and adjusting the the spring for pre boost. Their might be more, in fact I'm sure their is because I have a lag between 45-60 but it pulls hard everywhere else.
https://www.dieselbombers.com/5-9l-1...-p-7100-a.html
Old Oct 19, 2009 | 10:53 AM
MotorOilMcCall's Avatar
The AFC is controlled by the AFC Spring. The spring can be changed with a performance one, although it doesn't do much IMO. You can tune the AFC itself with the star wheel, located under an allen plug. Should be an 8mm wrench to loosen it, and they are TIGHT from the factory. If you have a socket in 8mm allen, I'd use that. I snapped a standard hex wrench on it before. Loosen is towards the block IIRC, that'll fuel harder down low. Basically, the looser the starwheel, the lower boost the fuel comes on.
Old Oct 19, 2009 | 03:58 PM
BAD ASS RAM's Avatar
you take it off and flip the washers around in the back where the diaphram is,then you take the barrel out and gring .090" off it,then hook an air line to it where the boost line goes and adjust it with the star wheel to where the foot is all the way foreward at whatever psi you want it to max out at.
Old Oct 19, 2009 | 05:37 PM
Or gut it... But I wouldn't do that for the street.
carid
Diesel Work Trucks
Nov 13, 2020 09:25 AM
DirtyDiesel58
18
Sep 27, 2015 07:07 AM
carid
Diesel Bombers Sponsors
Jun 22, 2015 09:33 AM
jrsavoie
Shade Tree , Pro-Mechanics & Fabrication
Nov 25, 2014 09:48 AM
