removing the fuel plate.
Old Oct 17, 2009 | 08:02 AM
monster12valve's Avatar
Default removing the fuel plate.
when you remove the fuel plate wht do you do with the rod inside? to do all i would do is remove the afc take out the plate and put the housing back on? thanks in advance.
lso is removing the plate bad for the pump? some places i read it is some places i read it is not.
Last edited by monster12valve; Oct 17, 2009 at 08:02 AM. Reason: Automerged Doublepost
Old Oct 17, 2009 | 08:23 AM
94 12valve's Avatar
it will not hurt the pump to run plateless. to run plate less you just remove the fuel plate and put nothing in its place. If I were you I would leave the afc in there and tune it ( it makes driveing so much easyer).
Old Oct 21, 2009 | 12:10 PM
BLACKSMOKEMOAN's Avatar
what do you mean by tunning the afc housing?
Old Oct 21, 2009 | 02:28 PM
94 12valve's Avatar
setting the amount of boost you need to see before you get full fuel
Old Oct 26, 2009 | 11:45 AM
How do you do this?
Old Oct 26, 2009 | 08:10 PM
lodal cummins's Avatar
play with the boost screw on the back of the afc. then play with the star wheel, turn it toward the front of the motor. flip the washers to allow more rack travel. that's what i did, but it took awhile to get it the way i wanted.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Nov 15, 2014 07:35 PM
